Review: 2020 Hyundai Kona Ultimate AWD
William Maley
Nearly two years ago, I drove the then all-new Hyundai Kona crossover at a press event. It was a unique looking vehicle that was entering the growing subcompact crossover class. Out of the three Hyundai vehicles I drove, the Kona impressed me most with its performance and value for money. But if there is something I have learned over eight years with reviewing vehicles, is that I can’t take first impressions as final. It has been a long wait, but I finally got my hands on a 2020 Kona Ultimate AWD. Let’s see if my first impression can still hold up.
The Outer Limits (of Exterior Design)
You may be forgiven for thinking that the Kona has just arrived in a UFO from Planet Nine due to its shape. But Hyundai knew they needed to make a splash in what is becoming a very competitive class. Designers took some influence from the Jeep Cherokee with a rounded front end and the front lights being separated into daytime lights and headlights. Another design trait is the slit that sits between the grille and hood cutline. Finishing off the look is body cladding running along the lower edge and a bright green paint color only available on the turbo engine models. It may seem like an odd mashup of ideas, but it works surprisingly well.
A Conventional Interior
Some will be disappointed that Hyundai didn’t continue the wacky design for the Kona’s interior. But having an interior that is user friendly will always pull ahead of interesting design. That isn’t to say Hyundai hasn’t added some special touches such as vent surrounds and seat stitching matching the exterior color. Hard plastics are used throughout, but they don’t feel hollow or cheap when you run your hand across.
There is a fair amount of space for those sitting upfront. Comfort is ok for short trips, but I found myself wanting more thigh support on longer trips. In the back, there is a large amount of headroom for most passengers. Legroom is a different story as tall people will find their knees pressed against the front seats. Cargo space is another area where the Kona is lacking. With the rear seats up, the Kona’s cargo area measures 19.2 cubic feet - about 0.1 cubic feet more than the Toyota C-HR. Fold them down and space increases to 45.8. This trails the likes of the Chevrolet Trax, Nissan Kicks, and Honda HR-V.
The One To Still Be Beaten (Infotainment-wise)
The Kona Ultimate comes equipped with an eight-inch touchscreen featuring Hyundai’s infotainment system. This system has consistently been one of my favorites as Hyundai nails the basics - simple interface, blazing-fast performance, and having features such as Apple CarPlay and Android Auto. My only complaint is that the design is starting to look dated when compared to other automakers and their updated infotainment.
Turbo Power!
Two powertrains are available in the Kona. SE, SEL, and SEL Plus use the 2.0L four-cylinder offering 147 horsepower and 132 pound-feet of torque. It’s paired with a six-speed automatic. Limited and Ultimate come with the turbocharged 1.6L four producing 175 horsepower and 195 pound-feet. This is paired with a seven-speed dual-clutch transmission. Front or all-wheel drive is available for either engine.
Zippy is the word to describe the performance of the turbo engine. The Kona easily accelerates away from a stop and has no issue with passing a slower vehicle. The dual-clutch transmission seems to stumble when leaving a stop, but does get itself together at higher speeds. I also found the transmission is slow to react when your floor the throttle, taking a few milliseconds to downshift.
EPA fuel economy figures for the 1.6T with AWD are 26 City/29 Highway/27 Combined. My average for the week landed around 26.7 mpg, mostly due to cold weather during the week I had the Kona.
Woah, This Crossover Handles
If you wanted a subcompact crossover that handled decently, your choices were either the Mazda CX-3 or Toyota C-HR. The Kona enters the ring as the third choice, and possibly the best. On the backroads, the Kona feels quite agile and has almost no body roll. If I was to nitpick, the steering doesn’t have as much feel as you’ll find in the CX-3. But it feels noticeably better than the C-HR. Ride quality is impressive with most bumps being isolated from passengers sitting inside. Not too much wind and road noise come inside.
Possibly the Best Subcompact Crossover At the Moment
Hyundai has a very compelling package in the Kona. There is an excellent performance from the turbocharged engine, impressive driving dynamics, easy to use infotainment system, and a long list of standard equipment. There are some drawbacks with the small cargo area and rear legroom topping the list. If you need the space, a Honda HR-V would be my first pick. The dual-clutch transmission still needs a bit more work to iron out the hesitation issues I experienced.
That first impression I had still stands and moves the Kona not only being the best in the class at the moment, but also onto a very rarefied list; a vehicle I would considering buying.
How I Would Configure A Kona: The only reason I see buying the Ultimate is for the adaptive cruise control as most of the other safety equipment such as blind spot monitoring, parking sensors, and forward collision avoidance are available on other models. So if I wanted the Turbo engine, then I would step down to the Limited at $26,100. For those who think that is a tad expensive still should consider the SEL Plus as it comes very well equipped for $23,950. You do sacrifice the turbo engine for the 2.0L four-cylinder which is fine if your planning to drive mostly around town. Add an additional $1,400 for all-wheel drive.
Disclaimer: Hyundai Provided the Kona, Insurance, and One Tank of Gas
Year: 2020
Make: Hyundai
Model: Kona
Trim: Ultimate
Engine: 1.6L Turbocharged DOHC 16-Valve GDI Four-Cylinder
Driveline: Seven-Speed Dual-Clutch, All-Wheel Drive
Horsepower @ RPM: 175 @ 5,500
Torque @ RPM: 195 @ 1,500 - 4,500
Fuel Economy: City/Highway/Combined - 26/29/27
Curb Weight: 3,276 lbs
Location of Manufacture: Ulsan, South Korea
Base Price: $29,150
As Tested Price: $ 30,380 (Includes $1,095.00 Destination Charge)
Options:
Carpeted Floor Mats - $135.00
I think this is a pretty good package and the turbo has pretty good power for a compact crossover.  Good interior on the Kona too, my favorite in the segment.  I agree that the limited seems the way to go, get the turbo and a lot of equipment but avoid that high price of the Ultimate.
We sell a heck of a lot of these.  I wish they'd do away with the DCT altogether and put a regular tranny in there with the turbo models.  I like the interior with either the orange or green accents and leather, the lower trims with the houndstooth cloth seems a bit blah.
I understand there is a Kona "N" model on its way, should be a hoot.
  • 4 weeks later...
