just curoius what every one thinks the most power N/A the 3.5 and 3.9 could do with things like direct injection, 3v, "performance breathing"? mine- 3.5L - 270hp 250lbft 3.9L - 310hp 270lbft
My belief is that GM could easily get more power out of their engines but dont because the mileage suffers and you cant beat the CAFE regulations and win sales if your not competitive in mileage, its more important than 10 -15 hp in the eyes of the average customer. So I believe they have kept them somewhat "choked" down. This has been my experience with the 38 anyhow. origionally they had something like .37 or .42 total valve lift, Im sure this improved as they got the engines worked out so the power was up and the mileage good. This is going to be the challenge for the 3.9, to get the power and improve the milage. It seems to me back when i did some power estimates on the V6's as if they performed equal per displacement to the LS1 or 2 ( I now forget which one of them I used) they would be around 260 on the 3.8 so just a tad more for the extra 100cc on the 3.9. If you wanted 280 or 300 you would be looking at serious performance mods like high compression and cam duration that would destroy the gas milage and require the expensive gas.......all sales NO NO's. Hopefully we will be seeing a supercharged 3.9......now that could easily reach 300 and maintain equal mileage under normal driving conditions.
i did push the numbers up just alittle , see what reactions it would cause. not tring to be an @ss about it though
GM did show-off a 270hp 3-valve 3.9l at Sema (2003 I believe). Direct injection would add (guessing here) another 5-10%? That would put it in the neighborhood of 285-300hp.
[post="65465"]<{POST_SNAPBACK}>[/post]
since you didnt stipulate this power level being from the factory, i think your numbers are a bit low.
